  ProbeTalk.com Forums > Performance Section > 2nd Gen (93-97) V6 2.5L Performance > 2nd Gen (93-97) V6 2.5L Performance Archive
2nd Gen (93-97) V6 2.5L Performance Archive Quality Archived Posts and FAQs
March 25th, 2004, 03:03 PM   #301
Rayman
I make T-shirts for PT!
: Aug 2000
: PT corner store
: 38
: 23,184
Re: Engine Build/Rebuild. Let's work together.
btw, the pistons are only 20 over, NOT 40
i'll talk to rob and see about the milling, he might be able to take care of that
NCPOC > BAPOC > SCPOC > FlaPOC > MIPOC
March 25th, 2004, 03:11 PM   #302
skelly
PT Guru
: Nov 2000
: The BAPOC Pit
: 6,208
Oh, good on both accounts - sanity checks are nice from time to time
March 26th, 2004, 03:17 PM   #303
skelly
PT Guru
: Nov 2000
: The BAPOC Pit
: 6,208
Okay another question for ya Ray: where do the new piston/rod/wrist pin/rings combo sit weight-wise compared to the same stock components? Same/more/less? If they're not exactly the same (which it seems to be it'd be a miracle if they were) wouldn't the difference need to be added to or removed from the counter weights on the crank depending on whether it's more or less?
I'm sort of in-progress with getting my engine guy straight on all the work I'm going to have him do while waiting for the pistons & rods to be ready and don't know whether this is something I have to add to the list..
Thanks!
March 26th, 2004, 07:47 PM   #304
Rayman
: Aug 2000
: PT corner store
: 38
: 23,184
the rods are virtually the same weight as stock, the pistons are slightly lighter than stock. so the RECOMMENDED thing to do is to have ur rotating assembly (crank/pistons/rods) rebalanced during this process. ur shop would be able to tell where to remove weight on the crank....since our motor is internally balanced, u wont need the balancer, clutch/flywheel, just the rotating assembly. but u cant do it ahead of time, the pistons rods and bearings must be ON the crank before u balance the whole thing
March 26th, 2004, 07:55 PM   #305
skelly
PT Guru
: Nov 2000
: The BAPOC Pit
: 6,208
hmm - when I talked to him today he indeicated that they spin the rotating parts (pulley, flywheel, crank) and then equalize the weights of all the piston/rod parts - he made no indication that that part was done as part of the "rotating assembly" - well I'll talk to him about it a bit more when it gets closer to time. I'm including the flywheel and UDP because they're both aluminum - no harmonic balancer - so I want everything perfect. Clutch won't be part of it though.
March 26th, 2004, 08:04 PM   #306
Rayman
: Aug 2000
: PT corner store
: 38
: 23,184
well they might be used to the more common engines that are NOT internally balanced....thats what my shop asked for at the beginning, they wanted my clutch and flywheel and other stuff, but i told them it was internally balanced and they double checked, and concurred that all they need is the crank w/ the pistons and rods installed
March 30th, 2004, 09:49 PM   #307
[]Drobekid818
: Feb 2004
: 14
Talk to you local shop. The shop here where I live in kansas. Is taking my engine. Truing the cylender walls. Cross hatching and honing them, Then they are putting new pistons, and new rods in. Then they are turning the crank. They are balancing and blueprinting it. And then port and polish heads. They are doing all the valves. And so pretty much when i get the engine back ti will be a short block. All i got to do is just slap a few things on and i have a motor making about 210 hp. And that is all being done for 700 dollars.
[]Drobekid818
March 31st, 2004, 03:04 PM   #308
Rayman
: Aug 2000
: PT corner store
: 38
: 23,184
depends on what CR pistons ur getting, ur motor alone will make far from 210hp
March 31st, 2004, 04:23 PM   #309
[]Drobekid818
: Feb 2004
: 14
so you are saying it will make more or less.
[]Drobekid818
April 2nd, 2004, 07:05 AM   #310
Rayman
: Aug 2000
: PT corner store
: 38
: 23,184
far FROM usually means less
if ur rebuilding using stock CR, u'll be around STOCK hp/tq....so im assuming u have a US spec, that means 164bhp....u are NOT gonna gain 50hp from port/polished heads. now if u have the ZE which is 200bhp to begin with, then yea, u might get 210 afterwards....
April 5th, 2004, 01:42 PM   #311
[]Drobekid818
: Feb 2004
: 14
oo ok cool. Thanks. But will a Ze IM make that big of a difference in this set u
[]Drobekid818
April 5th, 2004, 01:56 PM   #312
desertfox1313
Five Star Member
: Mar 2002
: SOCAL
: 35
: 3,805
he meant a COMPLETE ze engine... intake mani, chip, and 10:1 compression
Trevor
Got boost?
2003 Mazdaspeed Protege #695
Few tweaks but effectively stock. Going over two weeks without repairs... so amazing
April 5th, 2004, 08:46 PM   #313
Rayman
: Aug 2000
: PT corner store
: 38
: 23,184
and cams
the kits here are NOT for HP gain (except the 11:1).....they are simply for fortification of the bottom end to ALLOW/WITHSTAND the possibility for high power output
April 5th, 2004, 09:09 PM   #314
desertfox1313
Five Star Member
: Mar 2002
: SOCAL
: 35
: 3,805
High power usually meaning boost... or high revs
Got boost?
April 21st, 2004, 01:48 PM   #315
Bluexcell
: Oct 2003
: Norfolk England
: 279
ive been considering the PCM ( ECU ) problem for KL- ZE engines , since the one i have is a Eunos 800.
I have decided not to look for a KLZE PCM since they are like hens teeth here in the UK. I think there is an alternative that provides accurate and independent control for the VRIS and retains the existing PCM.
i have a wiki. it details the VRIS
http://www.incony.org/KLZEWiki/pwp_1...Page=StartPage
which details how i see the solution to the VRIS problem
i would welcome input from anyone here, particularly those of an electronic
disposition
