HOW TO: Escort Front Strut Mounts
  • HOW TO: Escort Front Strut Mounts
    This thread is a basic how-to on installing 97+ Escort front strut mounts in a 93-97 Probe. This is basically all the same steps as swapping out springs or struts on the front, with one extra step...
    Tools required:
    Jack and jack stands
    Ratchet (3/8 or 1/2 will work)
    Basic Socket Set (12, 14, 17, and 19 are the main ones you will use)
    Tire Iron or 21mm socket and breaker bar
    Pliers
    Strut Spring Compressor
    Dremel rotory tool
    Start off of course by breaking loose the lug nuts, but do not remove them. Then jack up both sides of the car and support them with jack stands, and remove both front tires. Make sure to either block the rear wheels or set the parking brake firmly before doing this.
    Loosen the nut in the center of each strut mount and turn it one turn. Do NOT remove this nut yet.
    Loosen and remove the 2 17mm nuts on holding the strut to the steering knuckle. Also, if your car has ABS like mine, remove the 12mm nut holding the wheel speed sensor wiring bracket to the strut. Remove the clip holding the brake hose to the strut and pull the brake hose out of the strut bracket. Then, use a hammer (or your ratchet ) to lightly tap the 2 bolts holding the strut to the steering knuckle out. You may need to move the steering knuckle around some to pull the bolts completely out. The steering knuckle should drop down a little now, and you should be able to pull it down and swing it out of the way of the strut. If the steering knuckle pops up towards the top of the car when you remove the bolts, it is most likely because you didn't jack up both sides of the car like I said to, and you are now fighting against the front sway bar. Now head back under the hood and remove 3 of the 4 strut mount bolts. Before removing the 4th, get a hand on the strut or spring, otherwise it will drop out under the car, which can do damage. After removing these 4 bolts, remove the strut and spring from the car.
    You should be looking at this now... Before proceeding, you will need to compress the coil spring using something like this:
    This is a strut coil spring compressor. Most auto parts stores that rent parts will rent these. These clamp down on the coils of the spring and compress them, to you can remove the pressure from the strut mount so you can remove it. Install them on the springs like this:
    Now, a little side note about these spring compressors. They are not the best or safest tool ever made. Most shops have spring compressors that mount on the wall and are alot more safe than these compressors. So, when compressing the spring, compress each side of the spring a little bit at a time. And, always keep the spring facing away from you, so that if the compressors slip (I've had this happen to me personally) no parts will come flying at you. Keep in mind that stock GT front springs have a spring rate of about 190 lb/in, and the springs will need to be compressed at least a few inches to remove the strut mount, so if that compressor slips, the spring will fly off there with about 600lbs of force behind it. It will hurt if it hits you, and it could kill you. So BE CAREFUL!!
    After you have the spring compressed to a safe level, you should be able to wobble the strut mount around a little, since you've loosened the nut a bit already. Once you are to this point, remove the strut mount from the strut shaft. Leave the bearing and the upper spring hat on there. Now, look at your Probe strut mount, and compare it to the Escort strut mount. You will see this...
    Notice how much further this mount puts the top of the spring to the body. It is about a half inch difference. This is how this mount is able to lower your front end about a half an inch without sacrificing any suspension travel. You will also notice that the D-shaped hole where the strut shaft goes through is much smaller on the Escort mount than the Probe mount. This will need to be fixed. In order to do this, I used my Dremel and a tungsten carbide cutting tool, which looks like this.
    This is designed to be able to cut hardened steel, so the strut mounts will be no problem. You could probably also do this with a large drill bit or a die grinder, but the Dremel worked best for me. Make sure that when you are enlarging the hole you keep the D-shape, otherwise you will likely have trouble tightening the center strut mount bolt when reinstalling.
    After you have gotten the hole to the correct size, slide the mount back onto the strut and snug down the bolt a little. Don't worry about really tightening it down right now, as that is much easier to do once the strut is back in the car. Release the spring compressors, backing the screws off a little bit on each side back and forth until they are loose. From this point, the installation is basically the opposite of removal... The strut to steering knuckle bolts get torqued to 68-86 ft-lbs, the 4 strut mount bolts get torqued 34-46 ft-lbs, and the center strut mount bolts get torqued to 66-86 ft-lbs. And of course, the wheels get torqued to 75ft-lbs in a star pattern.
    Continued in next post...
    Kevin B - Former Probe-owner
    06 Legacy GT
    98 Legacy GT
    So, what is the result of this work? Well, this is the front wheel gap when I started...
    And this is after...
    By my measurements, the distance from the center of the fender lip to the center of the wheel was 13.75" on each side before, and after installing these mounts it dropped to 13.25". So, it dropped the front about 1/2". I did this because I always felt that with a subwoofer in the trunk, my rear sat a little bit lower than the front. Without the sub in there, they sit pretty even. So, by doing this, the front now sits a very small amount lower than the rear...maybe a 1/4"
    As a comparison
    Before
    Before
    After
    After
    One thing worth mentioning is that I could not find any similar markings or anything on the two strut mounts, so I could not find a way to keep my alignment settings the same. So, I can tell now that my alignment is off, so I will need to fix that here pretty soon.
    So, that's pretty much it. If anybody has any questions, let me know...
    06 Legacy GT
    98 Legacy GT
      nice, can't complain about an extra 1/2", nice job that was on my list of stuff to buy aswell before I did my suspension.
      Kevin Heisler
      90 JDM Fairlady Z , twin turbo lots of stuff done already but not enough space in the sig
        Great write up. I'll be saving this for my car club.
          Only thing that I hated about doing this was that my Freedom Design strut bar does not go on anymore. So I'll be taking my mounts off.
          ~ PSE driver - James
          1996 Turbo'd 2.0 Zoom Zoom...
          1993 Mazda MX-6 LS
            Where do you buy the 97+ strut mounts? Ive been looking around
            95 pgt
            97 240sx
              My strut bar still fits fine. I don't know what brand it is tho, I got it as a gift
              I got the mounts from a local junkyard off of a 99 Escort. There were plenty of Escorts there... Tire Rack also sells them brand new KYB mounts, but they are $41 each. But it is a good alternative if you don't trust used parts.
              06 Legacy GT
              98 Legacy GT
                can i get this as an hmtl page?
                Let's get DANGEROUS!
                  Hmm, your "after" pics aren't working?
                    Working fine for me.
                      The mounts can be found on older 93ish+(mayber a year or two earlier) escorts as well.
                      1993 Mazda MX-6 LS
                        when one of the moderators edited my post to change those pics to links, the entered the after pics names in there wrong. I have fixed it so they should work now.
                        Damon, I will PM you with a address for a HTML version of this write up tomorrow.
                        06 Legacy GT
                        98 Legacy GT
                          good write up! I think I'll do this very soon.
                          Mike
                          96 PGT - 14.639 @ 91.54 mph N/A 2.025 60' - 2605 lbs
                          CS Lip ll Megasquirt ll ZE-IM ll Hotshot Headers ll PRM CAI ll Illuminas/Intrax ll 6 puck/MX3 FW ll RR Shifter ll 19" Giovanna Kobell Black Roof ll Black Leather
                          93 PGT-ZE - 14.433 @ 96.06mph N/A 2.159 60' - street tires - 2555lbs
                          ZEX ll Seli Cams ll Walbro ll Fidanza/DXD ll Addco ll PS Headers ll 65mm TB ll PRM CAI ll Blues and GC's ll MX6 Black Leather
                            Great write-up Kev! Those are the same shoes you always wear The car has the perfect stance now. Looked good before, but new and improved now!
                            1994 Aspen Silver Metallic Probe GT
                            Probes NorthWest Rocks!
                              I only own 3 pairs of shoes, those, formals, and sandals.
                              06 Legacy GT
                              98 Legacy GT
