this is so easy to do, but then the question gets asked all theim
price :$20-70 (depends where you get em)
need:
H4 housing
H4 bulb
H4 plug
(might come as a package)
crimp connector
heat shrink
time: under 1 hour
Raise the headlights, remove the plastic shroud. use a marker to mark the adjustment screws. just trace around them. this make re alignment a snap
after a few turns out
Remove the chrome headlight retaning ring (4 phillips screws) pull out head light and unplug.
cut off the factory plug for the head light. crimp connect the H4 harness to factory wiring (mine went black:black red/white:red/white red:red/black)
this is how I stop the H4 rattle, on the back of the H4 housings there a holes on the conners, a few small screws will be used to shim them up. about 1/4 in should work.
put the h4 bulb in the h4 housing, plug in and install in car.
need:
H4 housing
H4 bulb
H4 plug
crimp connector
heat shrink
time: under 1 hour
