Well, it was a lot quicker than I thought, only took a couple hours while I was doing my laundry. I even took pics throughout the process.
Before I get on to the pics I'd like to make a small disclaimer regarding this initial version. For this version I attempted to modify a probe crossmember to accept the rear mount mounting points for an mx3. It's a pretty straightforward and easy way to do it, but having some 1/4" steel stock laying around that you could cut to fit and drill holes for the rear mount may work better. Using part of the mx3 crossmember resulted in some lackluster welds and large gaps to cover. It's plenty strong the way it is, but when I do the next one I'll be trying the new method.
Cutout the area where the mx3 rear mount will come thru. You have to cut out pretty close to the holes where the xmember mounts to the frame.
MX3 and Probe xmember side by side
Mocked up a little
Pardon the exceptionally crappy welds, but it all sticks together. I had to use a couple pieces of square tubing to fill in some of the larger gaps. There's also a ton of welds on the topside not seen in the pics so it's a lot more sturdy than the pics may lead on.
Pic of the MX3Mount on the tranny on the top side of the xmember
And it even clears the lateral crossmember when you're done. Here it is all buttoned up.
Now we have to fill the motor mounts and Sean has to put on tranny #11 and we'll be out testing this theory. I would guess in about 2 weeks.
Mocked up a little
