im making a place to post your MSQ or images for comparison/discussion, if you like i can host them so they are always available (PM me). also provide as much info as you can as shown below:
Engine: straight neck full stock internal'd KLZE
Fuel Pressure: 32idle 40wot
Injector Size: 220CC (standard)
MS Version: V1, V3PCB MSnSExtra code
Relevant Problems: burning oil (leaky valve stem seals), overheating 102deg C
ECU: running IAC and A/C
req fuel:
**EDIT removed**
Target AFR Table:
**EDIT removed**
VE Table:
http://i299.photobucket.com/albums/m...latesttune.jpg
Ignition Table:
ive found a lot of people dont want to share this info due to dyno expense etc thats completely understandable, bear in mind most of the settings for one person will be useless for another person due to the differences in mods etc. with that in mind ill be coming back and editing my post with the most relevant tables. ill upload my MSQ later. im interested to see what other peoples target AFR tables are.
req fuel:
**EDIT removed**
Target AFR Table:
**EDIT removed**
VE Table:
Ignition Table:
