A little F40 Update
  • A little F40 Update
    I am in the progress of updating the update here.
    So I am now posting up some early photos of comparison shots:
    Mini-me & 500k "Old Gal" RIP
    Restoration of a legend
    Great to see the progress!!! I still have that f40 in my garage waiting for this project to be done.. I have 3 pgt's so ill find one of them to put it in.. Keep us posted!!
    http://www.supermotors.net/registry/20602
    http://www.supermotors.net/registry/20602/73905
      Very nice update!
      93 PGT Kitted and all -sold,
      Current 93 PGT-ZE-T So far: 12" brakes, ZE, T3/T4 turbo, 2.5" exhaust , ACT 6-puck, MSD6AL+2step, Coilovers, 245/45/17x9 cobra r, 67mm TB, MS II, traction bars, meth inj. and more.
        Nice to see actual progress but in the mean time we are getting OLD! Use another machine shop LOL
        1993 Mercury tRacer :Vitara & mFactory: In progress 2020
        2014 Factory Five 818s: sold
          A good G series must die for the cause:
            What is an F40 trans?
            Anthony D. Christiano
              g6 gtp 6 speed
              93gt 230k dd.
              1993 probe gt
              96 pgt 135k dd
              http://i86.photobucket.com/albums/k1...100_3918-1.jpg
                [link to non-vendor site removed]
                ¶¶¶ Spyder Mica Metallic1994 PGT ZE-T04E Intercooled @ 6 psi.. ----- Sold within NEPO and PT
                ¶¶¶ Arancio Atlas Metallic1995 PGT NOVI 1000 Intercooled @ 10psi. ----- STUPID FAST
                ¶¶¶ Verde Mica Metallic 1993 PGT Modified, Sanctified, Retired. ----- Damn I miss her.
                  Excellent
                  PhotoPOC(tm)
                  MM9 MMX FF FF2 FF3 FF4 FF5
                  93' PGT not stock, Bonneville LSR build
                  91' PLX MTX stock
                  95' Jaguar XJR 155mph La-z-boy recliner
                    Originally posted by KLZE Porsche View Post
                    The only problem with this is that the starter gear will be striking the flywheel ring gear from the back side and eventually it might be able to hammer the ring gear off even though Fidanza's have small bolts holding it in place.
                    those bolts really do nothing.
                    the ring gear is a pressed fit they heat the gear til it expands, then pressed over the fw centered, then cooled.
                    i'll grab a pic of a fidanza fw i had fixed my a friend who owns a machine shop. (where he builds connecting rods for Howards Cams)
                    my fw had a the ring gear spinning in place. now its held with 10 tapered locks.
                    2003Subaru WRX E85stock td04,tgv deletes, full catless, custom 2in crosspipe, 3in TBE, walbro 255,850 modded injectors,grimmspeed crank pulleyTUNED by me on opensource 12.8 @105mph 1.7 60ft
                      OH..i soo want...this will be bad a$$ behind a turbo car. talk about top end when this is done... i will scavenge the parts needed to not only turbo my car, but 6 speed swap it I have been waiting for this for quite some time
                        I realize that they are shrink fit but I think it is still somewhat of a concern. But I won't worry about it unless it actually happens. I will have to re-wire the starter though to turn backwards.
                          so what are the chances/possibilities of an adapter plate?
                          95 mx6 with a 4 lug swap
                          Built, Not Bought.
                            Chances for an adapter plate are non-existant! The input shaft is already too short to hit a pilot bearing and an adapter plate that adds an inch or more would only move it even further away. This tranny is meant to hug up close! The Fiero guys just don't run a pilot bearing. But a lot of them also complain of excessive vibrations. Well Duh!
                            I just can't do that because -I like to do things the right way! My Quaife is on it's way here!
                              Wow thats amazing Klze, I havent been on here for a long time. Nice to see probes are still going strong!
                              Legacy GT 05 - FP Green - Sold
                              SS Cobalt - Sold
                              E46 BMW - Current.
