I have wanted to remove the ps from my car for a long time now but I have always been kinda uncomfortable with the idea of it slipping off and leaving me stranded someday. So I started doing so research and found a ribbed pulley that uses the same bearing as the stock pulley does. The pulley is off a 97 chev p/u with a 350. The belt is a 285k4(28.5'' 4 groove).
http://i48.photobucket.com/albums/f2...e/IMG_0857.jpg
Now the downsides, the pulley is a 6groove and slight modification has to be done to oil pump casting in order for belt clearance.
These are the two pulleys side by side
http://i48.photobucket.com/albums/f2...e/IMG_0840.jpg
They are pretty close in size but the new pulley has a little smaller diameter and is a little shorter, but the bearing is exactly the same.
http://i48.photobucket.com/albums/f2...e/IMG_0841.jpg
bearing with locknut in place.
Since the new pulley is 6groove it is deeper than stock so you have to push it away from the tensioner assembly a small amount. I used 1 3/8 flat washer to get the space.
http://i48.photobucket.com/albums/f2...e/IMG_0844.jpg
This is the space the stock pulley has
compared to new ribbed pulley with 3/8 washer and factory spacer
new pulley installed on tension assembly
http://i48.photobucket.com/albums/f2...e/IMG_0847.jpg
The belt will hit on the casting of the oil pan so a small amount of material has to be removed in order for it to not drag.
I used a dremel with a gringing stone and a file to finish it off.
http://i48.photobucket.com/albums/f2...e/IMG_0854.jpg
Once you have removed enough mount everything to the motor. Here is an alignment shot of the pulleys. Since the pulley has a 6 grooves it leaves 2 grooves unused. It makes for a small amount of aditonal adjustment. I placed my belt in the center so I had 1 unused groove on either side of the belt.
pull out the slack in the belts and lock the locknuts and thats it. Only hard part was cutting out the section of the oil pump casting but that still was only about 10-15 min. Overall time do do swap was maybe an hour. Hope this helps some people out.
