Finally some progress!
Well I finally got my first KJabusa bored block back from the machine shop (after 3 months of impatient waiting). Here are a few pics.
Fresh bore:
Chopping the cradle:
Cleaning up the chopped cradle:
I found that the original SC cradle makes a perfect cover plate for the separated chambers. It is also much lower profile than a stock KL water log. This will make room for other things up top while providing a somewhat stock water flow path.
This one is going to be purely N/A just to test to see if this combination will be successful or should be abandoned. I had originally intended to turn the tapered noses of the KJ cranks to be identical to KL cranks but then I realized that since the gargantuan pulley assembly removes from a special hub that mounts to the tapered nose -I think I can use this hub to mount HTD crank pulleys to. So this might actually be a good thing!
Tapered nose and hub:
Fresh bore:
