Hey everyone, just wanted to show everyone what happens when you get a ZE and you dont do a check on the engine and you dont change your intake retainers. This engine lasted me approximately a month and the valve dropped. Gigantic waste of time and money. Check it out!!
KLZE dropped a Valve
Last edited by randledaman; July 4, 2008, 08:06 PM.96 Probe SE- klze with DE valve train, 18" chrome wheels, 35 series rubber, ACT stage 3 clutch, fidanza 9lb flywheel, pro 1 headers, cold air intake, bored out TB, rr racing inserts, sts.Tags: None
Ouch man, that really sucks....
Makes me happy knowing I put in the DE valve train on my ZE heads..93 GT Rio red: H/E/I -HEI mod -MSD -67mm RC TB -Fidanza 9lb -ACT 2100 -4G GRND kit - Ported and Polish ZE heads&cams, intake -Dinan ECU -AC delete -Illuminas w/1" drop -AWR trailing arms -AWR engine mounts -Addco 22mm sway bar -STBS -PMO X-member -New engine mod-13in Wilwood BBK-
+1, 7k redline is plenty
still sucks though00 Saturn SL2, boosting @ 15-20 psi
Gimme an SRT4 for breakfast! Boosting plastic appliances is fun.
Engine: fully forged, 8.5:1 CR, p&p, balanced to 9k, T3/T4 .63 turbine, FSR cams, meth-injected..
"There is a replacement for displacement, and it's shaped like a snail"
Originally posted by SlaveLabor View PostOuch man, that really sucks....
Makes me happy knowing I put in the DE valve train on my ZE heads.."I come from a very big family, nine parents."
"Never let the truth stand in the way of a good story"
does this only happen if you redline it or go over 7k?'95 MX6 LS-restoration in progress,...and bolt ons!
'12 Malibu-daily
RIP- '93 MX6 LS,Boosted 7lbs,180 stat,udp,2.5in exhaust w/hooker aero chamber muffler w/3in tip,S2 clutch,11lb flywhl,strut bars,eibachs,monroes,awr f/r mm,awr sway bar kit,b&m shifter w/rr-racing&corksport brass bushings
Originally posted by mx3autozam View PostI don't think thats a droped valve. Looks like you broke and intake and Exhaust valve, the valve stem is still inside the head. Flip teh head over and take a pic of the retainer and spring!
edit: nevermind, I see the second stem now. weird00 Saturn SL2, boosting @ 15-20 psi
actually this happened because i mis shifted and my car went to about 8k rpm, but yea that was an awesome engine really clean when i got it, i got a new one now from tiger japanese and its really dirty and dark brown under the valve covers, im gonna be switching all my intake valves over. what happened is the retainer snapped in half, half of it is still in my hla and it took the other valve with it. i inspected all the retainers later and found a few more intake ones cracked, no exhaust ones tho. The piston hit the stems and bent and jammed them into the head i cant get them out. I would recommend if your KLZE starts ticking loud suddenly dont drive anymore check your valves, because i thought it was just a HLA but i was wrong lol.Last edited by randledaman; July 4, 2008, 10:47 PM.96 Probe SE- klze with DE valve train, 18" chrome wheels, 35 series rubber, ACT stage 3 clutch, fidanza 9lb flywheel, pro 1 headers, cold air intake, bored out TB, rr racing inserts, sts.
Originally posted by mx3autozam View PostOr just put DE valvetrain in..best thing i ever did!
Like my95gtprob said, DE retainers WILL STILL FAIL!!!! I know this for a fact because I was replacing his DE retainers on his ZE on a weekly and sometimes twice-weekly basis! The total came to around 30 retainers cracked/ broken before finally dropping a valve. After an expensive repair to the damaged head, an extra 200 dollars were spend on some Interprep springs and he can now beat the absolute piss out of the motor without worry.Jim K.
:89LX: Gone but not forgotten:96 PGT:(ze twin turbo) Its not purple dammit! Its BOYSENBERRY! :89PGT: New project :03 KLZE Protege5: Daily When I go for a drive, I leave life behind. Friends, work, everything. Its just me, the car, and a twisty road. The exhilaration of being on the edge of catastrophe is something that I will never be able to give up.
