The Joe Bialy GM Ignitor Replacement
  • The Joe Bialy GM Ignitor Replacement
    Diagram of HEI Installation
    Re: The Joe Bialy GM Ignitor Replacement
    Nice clear photos and descriptors. But yeah, work on those soldering skills. Yikes!
      dammit Ryan, fix your links
      2014 Fusion SE MTXtreme
      2005 Mountaineer Premier
        Very cool, so where exactly did you mount that in you car?
        Previously: 93 PGT Turbo...you know, back when you had to build the setup yourself.
        Currently: 2012 Jeep GC Overland Summit - 1965 Chevy C10 SWB Fleet
          i like the idea of having this sitting in my glove box just in case type shit, cus everytime a disty goes its in a situation where the able mechanic cant even fix it right there.
          Chris Rose
            Definitely a big to Joe for his idea. I'm definitely thinking of a glove box add-on considering it's the simplest of things to do. Thanks, Ryan.
              Hmmm, only if somone made a plug in adapter kit for this . . .
              1997 Ford Probe GTS Turbo | 2000 Jaguar XJ8 | 1988 Jeep Grand Wagoneer | 1930 Model A Hotrod | 2005 VW Touareg V8
                Future PRD product ?!?!
                '96 Rio Red PGT - Sold
                  so what exactly did you just do and why did you do it?
                  Lots of cars... none of which are a Probe...
                    2.5's esp 93-94 are prone to igniter failures, and the igniters are no longer available - and when they were they were hella expensive. The only fix now is a new distributor, however you can use a GM igniter for $12 and be up & running again.
                      ah, cool... thanks for the explanation
                        very cool. i will be doing this shortly with a ze disty and msd coil.
                        '59 VW Bus - camper - lots of work - Mango green/Seagull Grey two tone
                        '05 Audi A4 1.8t Quattro 6-spd manual Ultrasport w/ mods - Arctic White / Black
                        '69 VW Bug - Grey/Black two tone-1641cc
                        '94 MX-6 ZE mtx w/ mods - TAZ 6 - sold / BAPOC
                        '01.5 Audi A4 1.8T Quattro w/ mods - sold
                          hmm.
                          i was originally skeptical of this solution, but now that i see a visual representation, i see what joe was talking about. looks like it should work just fine on the 93/94's and a lot less expensive than going with an MSD or other aftermarket ignition system.
                          personally, i like my MSD and wouldn't change a thing, but this is a good alternative to those who don't want to take the time to install one.
                          good job.
                          oh, changed the drawing to a link. over image res limit. sorry.
                          Let's get DANGEROUS!
                            Brilliant work, Joe! Thanks for taking the time to post this extremely helpful info.
                              awesome work!
                              The problem with the ingnitor modules was that they would heat up and go bad due to proximity to the engine. Does the HEI module heat up too? Nothing a small heatsink can't fix though.
                              Mad props
