I don't know about you guys, but I am personally sick of all the header threads being posted on MX-3.com and also on here. I wish people would search, although the information about all of the headers for the Probe are spread across LOTS of threads on here.
I decided to do a few searches myself & compile the information I could find. I thought that the price, primary, y-pipe & outlet sizes, construction, fitment, sound & power gains are what most people are concerned with when it comes to headers so I compiled all the info I could find & listed it below.
K-Series Engine Header FAQ:
Here is a list of the headers available and what I've found (from researching ProbeTalk):
Brospeed / Bosal Headers:
Price: $350-450
Description: Ceramic-coated mild steel construction. Short equal-length primaries. Equal-legnth Y-pipe that secures with a balljoint
Primary Size: 1.625" (outer)
Outlet Size: 2.5" at collector, then tapers down to 2.125" (inner) 2.25" (outer) to fit the stock cat size (for probes at least)
Power Gains: Dyno results varied from 4-11whp over stock. Torque gains were from 5-8 ft lbs. Gains were particularly good from 3500 and up. Peak power gains surpass hotshots but don't quite reach pacesetters results.
Sound: Described as raspy by some ProbeTalkers. Sometimes Rattles from 2000-2500rpm's due to balljoint design (lack of flexpipe)
Fitment Issues: fitment is good according to people on probetalk with these headers
Pacesetter:
Price: $180-240
Description: Mild Steel Construction. long unequal-lengthprimaries. Unequal-legnth Y-pipe that secures with a balljoint
Primary Size: 1.5" (outer)
Outlet Size:
Power Gains: I've seen varying results. As much as 17whp to as low as 7whp gains. Torque gains were anywhere from 5-10 ft lbs.
Sound: Very Raspy.
Fitment Issues: Pacesetter updated their design in 2004 for better fitment. Apparently there is still problems with the Y pipe bolting up to the primaries. The O2 sensor bung placement issues have been fixed however.
Hotshot:
Price: $410-500
Description: Coated Stainless Steel Construction. Short equal-length primaries. Equal-legnth Y-pipe that contains a flex-pipe.
Primary Size: 1.625" (1 5/8")
Outlet Size: 2.5"
Power Gains: Varying results from 4whp to as high as 13 whp. Torque gains seen have been consistent from 5 to 8 ft lbs.
Sound: Keeps the tuned sound of the K-series engine. Best choice for those who want the best sound
Fitment Issues: Fitment is great!
SSAutochrome:
Price: $175-200 on ebay
Same as pacesetter generation 1 headers but made with stainless steel which is less likely to rust. ALso the primaries are 1.625" (1 5/8") instead of 1.5". The fitment is the same however. O2 sensor bung placement issues & difficulty with the primary-y-pipe flange were voiced by people who bought these headers.
OBX (also called Stone Racing):
Price: $250-300 on ebay
Same as Hotshot headers. Stainless steel construction, decent welds, flexpipe, nearly identical to the hotshots. Fitment is also good.
Also note that SSautochrome sells these exact headers and uses their brandname on them as well. The ones I received from ebay came in a ssautochrome box with stickers. SSautochrome posted messages on ProbeTalk about redesigning their header design and I guess they decided to just knock off the hotshots
I have the OBX headers on my car and they fit fine with no issues. O2 sensors clear everything. My EGR bung is plugged so I don't know if that fits properly, but other than that, I'm satisfied. I've had them installed for 9+ months and they show no signs of rust, however the typical purple/orange/blue/green discoloration has occured on the primaries. I live in an area where it snows & they salt the roads and I'm particularly surprised that they show zero signs of corrosion so far.
Price: $350-450
Pacesetter:
Price: $180-240
Outlet Size:
Sound: Very Raspy.
Hotshot:
Price: $410-500
Outlet Size: 2.5"
SSAutochrome:
