I recently decided to see what it would be like to run my 03 Tacoma into a tree, needless to say it wasn't as fun as thought. I have been car shopping for awhile and stumbled upon a 1996 Probe GT with a ton of extras. So, I've decided to start my very own build thread!
I have until the end of May to build the car up to daily driver status with a few extras. I plan on doing so on a limited budget which I've set at $2000. With that I'll lay out some specs and a list of parts I plan to install.
1996 Probe GT, 5spd, ~120k, Loaded with peanut butter leather.
-OBX headers
-JJ Res TP
-Megan springs
-Manual Swap
-Unknown rims
-fidanza flywheel & stage 2 clutch
-Trans saver
Extra Items to be swapped
-KLZE
-Colt Cams (NA)
-67mm TB
-94 Harness
Replacement Parts
-All Timing Components & WP
-Gaskets VCGs, intake, TB, Seals
-All new fluids, filters
-New Tires Goodyear Eagle GT1
-Rear Brake Caliper
-New Axles?
Aftermarket Parts
-CF hood
-Chipped ECU
-New Blue's w/ Eibach's
-Magnaflow 14830 muffler
-Electric exhaust cutout
-Short Throw
-Walbro 255
-AFPR?
-Nitrous Express
-Mount Mount Inserts
-Contour sway bar
-Megasquirt?
-Yellow Fogs
-Single 10" or 12"
Build Steps
1. Repair rear brake caliper and transports to garage
2. Pull motor & Dash, Swap 1994 Harness
3. Assemble Klze with new parts, swap springs/retainers, colt cams & 67MM TB, Clean up
4. Install motor, first start up, after first start fails search for short in wire harness
5. Start Modding!
6. Make it to Bamm!!!! for test drive..
7. Drive from Illinois to Oklahoma
Goals (Pipe Dreams)
-Run low 14's NA (below 14.4)
-Trap 98+ NA
-Run mid 13's on 75 shot
Day 1 Pictures
-Alex
-OBX headers
-JJ Res TP
-Megan springs
-Manual Swap
-Unknown rims
-Trans saver
-KLZE
-Colt Cams (NA)
-67mm TB
-94 Harness
Replacement Parts
-Rear Brake Caliper
-New Axles?
Aftermarket Parts
-CF hood
-Chipped ECU
-Short Throw
-Walbro 255
-AFPR?
-Nitrous Express
-Contour sway bar
-Megasquirt?
-Yellow Fogs
-Single 10" or 12"
Build Steps
5. Start Modding!
Goals (Pipe Dreams)
-Trap 98+ NA
Day 1 Pictures
-Alex
