Crankshaft Oil passage redrilling
  • #16
    Ryan,
    speaking of the O-ring, do you have its part number by any chance? I've taken mine apart and swapped the good O-ring from the other cooler and dont have any problems with it, just to have for a black day!
    Rio Red 94PGT, Turbo T360trim,T3T4E 50 trim,T3T4E57 trim Parted out!
    1998 Volvo S70, The Brick
    1999 Red Volvo S70 T5 The Red Devil, modded
    1998 Black V70R AWD, The Waggo with mods
    • #17
      That I don't, but any Mazda dealer should be able to get it for you
      Ryan
      Ryan
      '94 Mazda MX6 V-6
      SMF Prep:
      MFactory LSD [] TEIN [] 15x11's and 275 Hoosiers [] Hawk HP+ [] Sparco [] AWR [] HotShot [] Headers [] Magnaflow [] Side Exit []
      • #18
        I opened the oil ports on the block after I spoke with Alistair from Interprep.
        That's what he did to his KLZE engine, along with shimming the oil pump.
        He said he raced his car, frequently hitting 8K RPMs, and never had a problem with a spun bearing.
        I think I read somewhere that Alistair also participates in 24-hr endurance races.
        It appears as though the KL engines went through a revision in terms of the oil port dimensions, after the first or second year.
        IIRC, the oil ports on my KLZE were .375" at the bearing interface and tapered down to .270" into the block.
        There was another member who measured the oil ports on his '94 KLDE and he said his were .400" at the bearing interface and .375" into the block.
        I guess mine was an early KLZE.
        My oil ports are now between .400"-.410" straight through.
        Originally posted by RigsPGT View Post
        Ryan,
        Rigs,
        If you're referring to the red O-ring for the oil cooler it's
        Mazda Part #: KL01-14-702A
        • #19
          So, with larger gallies, and the shimmed pump, what is your oil pressure at idle, and say at 3k rpms as compared to stock?
          Ryan
          '94 Mazda MX6 V-6
          SMF Prep:
          • #20
            My engine is not fully assembled yet.
            • #21
              Rigs,
              Just out of curiousity you don't have pictures of the ports you are enlarging do you?
              93 Probe GT 5 spd sunroof - Finally Done !!
              69 Mustang Mach 1 AOD 351W
              89 GMC 2500 5.7
              99 Burban - Daily Driver now getting retired for my probe !!
              • #22
                Oil gallies.
