Hi guys,
Thought Id introduce myself like on MX6.com.
I have 1994 Miata with 1993 KLZE and currently running a KL01D ECU with KL-02 VAF.
Building the car for Time Attack and lapping (what you guys refer to as HPDE).
Here are a few pics:
This is what the engine bay looks like, except with NGK wires now:
So...
Step 1:
I just bought a used MSII V3 Board with custom harness for MX6 with piggy back for stock ECU (I assume for idle control).
I inspected the board thoroughly and all mods are there for KL engines. Harness is well done with identifications. Came with the GM IAT. (need a bung).
I just plugged into it and it detected the firmware 3.2.1.
Now I need to figure out how to use TunerStudio MS
BTW, I opened up my KL01D ECU and there was a chip in it, but I cant find much info.
Anyone know anything about this chip?
INNOVATiVE AUTOSPORTS
FORD PROBE KLZE RACE
I'll install the IAT, and MAP hose, calibrate sensors, and install a Wideband.
Get rid of the VAF.
------- From there, I'll get the car running with the ECU and base tune. Fix any bugs, if any and maybe do a dyno run for future comparison.
Step 2:
- I'm debating between a coilpack, like the Ford Explorer ones or COP...
- Custom plug wires....???
- Fabricate bracket of some sort to hold the coilpack
**** Now, this is where I see lots of info, but from different years.
What is the BEST setup for running coilpacks with a MSII V3 board??
If you can see in the picture, my distributor is against the firewall. It means lifting the engine just to remove it. So the disty and cam sensor just might stay in there. I'm thinking of using the camshaft sensor instead of a 36-1? or is it preferable to just be a man, lift the engine and get rid of the disty?
----- Once I get coilpacks sorted out, I'm going to do more base tuning and get it running properly, probably some dyno tuning as well.
Step 3 (end of summer or over winter):
- Get TWO GSXr 1000 ITBs
- Cut off the 4th throttle intake on each
- Fab a bracket for fuel rail
- Whatever other fabrication is necessary to make this run
---- Tune dyno, dyno dyno, tune.
OR... supercharge it... decisions decisions...
Until then. RACE the shit out of the car till the engine dies.
THEN, build high revving KL 2.8 engine
Guys, Ive done allot of research. I think I have most of this understood.
Autotune should help me here.
Is there anything major that I forgot? Anything that can be done differently, better, cheaper yet still good?
Any input would be appreciated.
Thanks !!!
Chris
p.s. I have been lurking here and MX6.com for the past few months and reading up on tons of great info. I would like to thank the community and administrators for the wealth of information contained here.
So...
Step 1:
Get rid of the VAF.
Step 2:
Thanks !!!
Chris
