Today (after over 3 years of boosting just less than 4PSI) i decided to start working on putting the overdrive pulley on.
The hard part is done and it appears the new pulleys timing marks are only off by about 2deg which is pretty acceptable:
The new pulley in the same position:
Clears my PS delete pulley nicely:
Just need a longer belt for the SC and the dirty work is over.
Any-who has anyone else ever fitted one of these? If so can you please share your MS settings as ive gone from the factory crankshaft sensor (6-0) to this 36-1 wheel and a starting point will make the rest of my job much easier.
