So that's it, that completes the build log for the monster, she is done.
I left the FMIC 'projections' sticking out of the lower rad. support in place (even though I no longer have the FMIC) because they would be a perfect place to hang ballast from - very far forward, and very low to the ground. 100lb of tungsten would do quite well for traction.
For single digit passes, it has the power, it has the gearing. It needs the axles, and more track time to tune (boost can be tuned any way possible using the APEXi AVC-R), and the suspension settings can be adjusted in any number of ways.
Wheelie bars would probably be another good option - the possibilities are endless.
The final weight of the car is 1950 lb wet.
Final numbers are ~600+ bhp, 450+ torque (lb-ft) @ 20 psi boost. Engine is built for ~800hp.
