I pics are kinda out of order but...
The bottom one is of an FC RX-7 control arm made to work for a BG but since the arms are shorter and can't work as is, I had to order some extended RX-7 ball joints normally used by the drift crowd to get the correct length which is the top picture. The arms use modified urethane bushings but I have a guy currently working making spherical bearings for them. The second picture is of some used Good-win racing rear Miata 2-piece sport rotors to replace the single piece rotors I had before. The 3rd picture is me making a brake caliper bracket to mount Wilwood dynalites to some Kia BG knuckles. The bracket I made from a kitchen cutting board and used it to transfer measurements to paper to make a real set of brackets to also go with some 11" Wilwood 2 piece front rotors.
