I notice you said you have 8" 275 in front and that you thought they were binding often.....could that be because you're not using bumpstops? Bumpstops would help prevent the spring from compressing as much. Greg was running 8" 300 Ground Controls with bumpstops and he never had that kind of problem
A couple questions on LEDA suspension
I'm sure that's a factor in it, yes. The LEDA guys told me I was supposed to re-use the stock bump stops but it didn't look like they fit on the strut shaft. But also, just watching the car at rest vs on a lift, I see the front springs naturally compress way more than the rear. There's practically no compression remaining, to begin with... Very likely the springs got trashed over time because of the lack of bump stops.-- Howard Chu Chief Architect, Symas Corp. Director, Highland Sun
17x8" BBS RC/Leda 24-way adj. coilovers/Hye-Dra-Cyl Big Brakes: Wilwood 4-piston calipers+12.2x1.25" rotors/RRE FSTB/Top-End Racing FW/MazdaSpeed-Quaife LSD/65mm TB/Autophysics CAI/Groundz/Bi-Xenon HID headlamps/Euro Clear-corners+amber LEDs/Blazer amber fogs/JVC KDMX3000+CHX1200/Pioneer 6x9s/BCT7 Scanner/etc...
Originally posted by Hans[93GT]
If it doens't have a D-shaped shaft, how does the mount hold it tight enough to prevent it from turning when you steer? That's the whole purpose of the factory D-shape. BTW nice to hear from you again!-- Howard Chu Chief Architect, Symas Corp. Director, Highland Sun
8" 375lb front is the way to go, the ride isn't noticably harsher over mild bumps and there's no longer any jarring coil bind over bigger bumps. The rears were ok at 9" 225 but I just upped them to 9" 250. I think that should alleviate any understeer tendencies that the stiffer front might have caused, the rear is definitely very live with the 250s. I have a lot of adjusting to do to dial things back into a comfortable zone.-- Howard Chu Chief Architect, Symas Corp. Director, Highland Sun
Considering that I had no bumpstops at all, I think raising was the right thing to do. But now I can mess around without worrying...-- Howard Chu Chief Architect, Symas Corp. Director, Highland Sun
