Ok well I know I know its about time.... I'm so sorry...
Enjoy the pics... comments welcome..
Toodles
Close up view of the Twin 4" dia. scoop with a mesh screen.The screen has some miles on it.. so be kind...
(2) 3" tubings connect to the back of the scoop and then join a 3" tee where (1) 3" dia. hose follows up the fender into the modified silencer section
At the top I took the top section of the stock tubing that connects to the box and cut it and joined the 3" dia. hose at this point and used the same rubber coupler and secured it down with hose clamps. When combined with a K&N filter you have a great system with much improved throttle response.
I will look for some more pics -- enjoy..!
BTW--- I can even set up a twin ram-air with (4)four 3" dia. hoses teeing into (2) tees then into (1) tee then up the fender. I've been wondering what kinda increase i would get with that set-up.. one of these days I'll try it. It's going to cost an extra $40-45 for it. Another thing that works here is this setup, is speed sensitive. As you go faster it works harder. The Ram-air effects are noticed at higher speeds. 5th gear is no longer a dog, for instance.
Toodles
