Full Suspension Rebuild Thread
  • #16
    Very nice! Should feel like a brand new car! I need to do a couple of those things myself, once I get the car licensed and such..
    John Kessler - 'The Original Mayonnaise'
    '95 Probe GT- Blurple-ish, SSR Integral A2s, D2 Coilovers, Renault Laguna Lip SOLD
    '96 Probe GT-Bolt-Ons, MS1 v3.0, Custom Suspension, The original Tri-Flow Turbo Cams, etc..Sold, and missed
    New? From Missouri/S. Illinois/Kansas area? Let me know!
    '95 M3/2/5-S366 2J Swap in progress
    • #17
      Originally posted by mac1 View Post
      so tell me again why remove the sub frame and rear tie rods? i'm sure you know you'll have to re-align it when done.
      I either remove the sub frame or the gas tank to replace the Lateral arms. Yeah, I know I have to get an alignment that's another reason why I'm waiting for all the parts so I don't have to do it more than once.
      Originally posted by 93probeanator View Post
      Good work I bet it's going to handle like a boss!!
      Thanks.Yeah, that's what I'm hoping for.
      ---------- Post added at 01:51 AM ---------- Previous post was at 01:51 AM ----------
      pink yo
      Thanks for the correction but it's Coral Mist
      Originally posted by plx92 View Post
      nice work man thats quite the pile of parts you got! dont quite understand the last pic. did you bring al your old parts in a car at the junkyard? or did you go to the junkyard and disassemble a rear subframe on another car? if you brought all of them to the yard what are you gonna do about a subframe and spindles?
      I got anxious so I went to the junk yard and found a PGT and took the rear apart and left all the parts there because I had no need for them.
      I know, kind of a waist of time but it's also relax time for me.
      1994 Coral Mist Metallic PGT
      http://forums.probetalk.com/showthread.php?t=1701308460
      • #18
        "its not pink its coral, its not purple its boysenberry" lol
        I like to call it salmon lol
        1992 Mazda MX-3 GS - KLG4 Turbo
        Scott
        • #19
          Any updates bro?
          96 pgt 15000mls on rebuilt, kl31cams, ebay sts, 9lb flywheel,16mm 626 sway bar, stage 2 clutch, chrome 5 stars, Ground Control coilovers on Illuminas, OEM mudflaps, window sealer mtr mnts. 17" XXR 962's. http://imgur.com/a/zHp21
          • #20
            damn didn't know he made control arm bushings, nice.
            he doesn't. those are energy suspension bushings.
            you shouldn't need to. i've had to replace one of mine and i never had to remove either.
            nice to see all of the work you're putting into the car. i recently replaced my control arms, inner tie rod ends, and outers. had fun with it, but found out i had to replace the right side rack boot and the passenger side axle. the axle was the kicker because that thing was only recently installed. turned out the joint itself was bad. eek.
            ProbeTalk is BACK! Once again, it's what you use the Internet for!
            Let's get DANGEROUS!
            • #21
              i want it.. haha
              1995 PGT BLACK: CF hood, stock KLDE, Clutchmasters FX400, MX3 Flywheel, MS1 Extra, KLG4 coilpack with PRD wires, T3T04e turbo, same side intercooler, tial WG, custom fuel rails with nissan 550cc injectors, Aeromotive FPR, AEM Eugo, Autometer gauges, 2.5" custom Borla catback, Tokico blues, Eibach springs, FD rims, J30 projector conversion......
              • #22
                Originally posted by usiel123 View Post
                Any updates bro?
                Sadly no updates yet. I'm still waiting for one more rear strut mount and the funds for a new rack n pinion.
                Didn't know that, I guess I got exited removing things. I might end up removing it so I can put a fresh coat of paint on it.
                Originally posted by no13regrets View Post
                i want it.. haha
                I want to get it all done so I can enjoy it.
                • #23
                  It has begun...
                  I wasn't able to go to the ACH cruse because more of my bushings gave away and didn't want an accident. You will see once I get done and post up the pictures.
                  • #24
                    Good luck
                    • #25
                      Actually I did this on my mx6, when i was changing the front lateral links, the way Mazda put the bolt is that it slides out and hits the tank. What i did was I cut the bolt, bought another one from the hardware store (12mm x 1.25) and put the bolt in the other way so the nut would be facing the tank side. I have no idea why mazda or ford did not do it that way
                      96' MX6
                      • #26
                        Originally posted by KnezicDex View Post
                        Good luck
                        Thanks
                        I just took the subframe out, it needed a fresh coat of paint. But it is a good thing you reminded me to put the bolt in backwards, just in case I have to chane something in the future.
                        • #27
                          It was some day yesterday, took all the parts of and some of which gave me trouble.
                          The first time I ever took the wheel knuckle off, I saw that the previous owner had tried to take the nut off but stripped it. I could not do anything with it so I got my drill and got to work didn't have to deal with that problem this time.
                          This is one of my lower control arms, I think it's bad. I could pull the center out by hand. The other one wasn't as bad as this one but still bad.
                          As for taking that bushing out, I decided not to use the torch and instead just got a socket and hammered away.
                          The biggest problem I had was in the rear of the car. First, the end links would not come off so I just left them attached. The rear spindle has a big bolt that holds the lateral arms, which I could not get out. What I did with the first one was to cut the bolt in pieces so I can remove the arms from the spindle. Once I did that, I tried to take the bolt out but nothing. So I decided to heat the bolt and out it came with the hammer.
                          The other side was easier because I just got the torch to heat it and out it came.
                          The last thing I did was put a fresh coat of paint on some of the parts and called it a day. I improvised with my ladder and some coat hangers as my drying rack.
                          Today is all about putting the new parts back together, should be easy enough.
                          • #28
                            Keep up the good work. This is inspiring.
                            And thanks for being courteous in the junk yard. I work at one, and trust me, a lot more people say they practice good etiquette than actually do.
                            Currently: 1994 MX6 RS - KLZE. Too many mods.
                            1989 PGT - BLACK - Near perfect paint, body completely straight. 155,967 mi. Sitting in a garage since 2000. Bought for $600. Engine rebuild in progress. Coming soon to a kill story thread near you!!!
                            • #29
                              Okay, I finally finished, for the most part. The sway bar gave me the most trouble because some of the bolts were too big and I wasn't able to tighten them. Also the AWR swaybar does not fit King's lateral arms, so I am going to see if I can use an extra pair of adjustable links for the mean time until I get the funds for the correct swaybar. Other than that, all I have to do is the allignment.
                              Here are some pictures
                              ---------- Post added at 10:52 PM ---------- Previous post was at 10:51 PM ----------
                              Thanks
                              • #30
                                Excellent job man.
                                This is one of those things that I've been looking at doing, collecting all the suspension parts, and soon it will all begin. Waiting for a 3 day weekend. Excellent work.
